Hi there !
Normally, i'm able to do my installs without relays. But this time, I need to use Feniex Typhoon Handheld sirens and controllers. For 4 of the outputs, i'm okay but for 2 of them, I will exceed the max. out Amperage of 1.5 Amp.
Which relay do you suggest me to purchase ? And if you can confirm my way of thinking about this :
- Wire the proper pin of the relay to my fuse box
- Wire the trigger pin of the relay to the output of the Typhoon HH
- Wire the proper pin of the relay to the bus bar with my lights connected to
Thanks in advance
Thanks in advance
