JohnMarcson said:I really like the piercealerts... it's too bad they have such a high failure rate. The wires for the bulbs run up trough the reflector and twist back and forth with each oscillation. The often snapped after a year or so.
LP6000 said:Can't wait to get my FREE XL9000 with Stinger on my F150. Never saw an oscillating Sentry...is that basically a StreetHawk oscillator in a Sentry housing?
TritonBoulder47 said:How did I know that a thread like this was coming...? LoL Again, I'm sorry for using the wrong term in the chat the other day... lol
On a serious not, great thread! Its cool to see the progression of this add-on... I personally LOVE these, in all their variations...
emtanderson51 said:Didn't all the Ohio bars have the halogen Piercers in them????? I would think they were easy to find....maybe not without the rest of the bar though lol
HILO said:Back in the early 1990's Richardson Tx. Police had some heavy loaded MX7000's. The bars had .... stinger to the rear in center section.....
HILO said:It might have been an oscillator. Was a long time ago.
JohnMarcson said:That's what I thought..... I was hoping to find someone with an OSHP bar with no controller that wanted to part it out.
Here is the part
02-0361931-00
Halogen Piercer 2 Assembly
JohnMarcson said:You mean oscilaser? That was a rear MX option.
jdh said:MX did have an option for stingrays from the factory. They usually went in-between the outer rotator and the inner rotator to replace the mirror. Also they did at one time have a sweep light for the upper sections that had the same sweep as a pursuit module, but went in the upper section.
JohnMarcson said::duh: Go jeeze.... read the thread. That was already discussed. We all know that you can put sting rays in an MX it says that in the OP and it is discussed specifically as well in a reply. Since he already said there were stingrays in the bar I assume he knows what those are. He specifically called it a stinger or an oscillator.... from that I gather he means oscilaser. Which sounds like oscillator but functions closer to a stinger.
shues said:I sold my Edge 9308 with (not-matching) PCDS-9 to rlsllc in December. I purchased it from a seller in Ohio last spring. It had a halogen Piercer II in it. Perhaps he's grown tired of trying to fix the strobes arcing at the diagnostics board and parted it out.
rlsllc said:@ Shues:
The Piercer II is on my 9438 Edge, I did gut the 9308 and I am in the process of rebuilding it as a high current bar. I'll get a vid of it when it is done, you'll LOL.
@John:
Just wondering if the strobe version has the studs in the housing to mount the halogen lights...I replaced the lamps in my Piercer II with the nice alley lights from the 9438; and used 400 series housings in 9M endcaps in their place.
Just a thought, although I know a Pierce Alert does not have the studs in it, I have not had a strobe Piercer apart (yet).
I have always liked the Piercers and Pierce Alerts; I so hope you build a bar with several of them on it. It would be the Aurora Borealis of Edge bars, well with the Pierce Alerts anyway. It would be pure awesomeness.
rlsllc said:I have always liked the Piercers and Pierce Alerts; I so hope you build a bar with several of them on it. It would be the Aurora Borealis of Edge bars, well with the Pierce Alerts anyway. It would be pure awesomeness.
JohnMarcson said:It's in the works.... Only thing I haven't figured out is what to put at the corners.....
lotsofbars said:Red strobes maybe?
JohnMarcson said:That was my first thought. I had also considered spreading the items out more and doing only the piercers and pierce-alerts with blacked out end caps. I had also though of doing clear strobes on a rapid rate high watt supply and make it a "traffic clearing bar". I also have the ability to make it a "wrap around" bar by adding some edgecap strobes.... the problem there is the bar is somewhat short to be a wrap around.
