With the programmer, you can set up the light as you described, plus more if needed, essentially you can have 6 different "modes" but you are limited to 1 flash pattern for the light. So you cannot setup a different flash pattern between the red wire and red/white wire and so on. Hopefully they will update the firmware/software to allow this in the future.
