Maglite XL100 (maglite out did themselves)
Jarred J.
Archive Expert
11,613
2,241
44
Shelbyville, TN
This is an EXCELLENT light for its price & size. Its very light weight.
I put it up against my S&W delta force and a 2 d cell led mag light and it was as bright as the delta force head on (since its only 7 lumens less) but brightness vs distance wise blew it out of the water.
its distance projection was same as 2 d cell led maglite.
Its powered by 3AAA Batteries which are considerably then the cr123's i normally have to buy.
Ot will last over 5 hours on high or 201 hours on low. (vs. 2 hours for the Delta Force)
Specifications:
Length: 4.8" (121.92 mm)
Barrel Diameter: 1" (25.4 mm)
Head Diameter: 1" (25.4 mm)
Weight with batteries: 3.68 oz. (104 g)
Features:
Normal Mode (Basic On-Off)
Adjustable Brightness with Memory (83 lumens at its brightest)
Strobe Mode
Adjustable Strobe Rate with Memory (rate and brightness adjustable)
Nite Lite™ Mode
Automatically Dims to a Low Setting (neat concept)
Signal Mode
User initiated signal on-off
SOS Mode
Signals International Morse Code SOS
Plus:
Lockout
Prevents accidental operation
there's only three things I'm not really liking about it so far:
1: the red tail cap switch. (would have preffered black)
[Broken External Image]:http://www.maglite.com/images/XL100_inset.jpg
2: no holster included (not really a "biggie" but this light is smaller then my S&W delta force so im using its holder for now)
3: when you go from spot to flood even at full brightness there is a considerable noticeable dimness to the light (optics?)
I bought mine from the guys at Big Country Supply in this thread....
viewtopic.php?f=21&t=982
I've used this thing a couple times at work now. One was while stuck on a road with a MASSIVE tree over it and had to wait on street dept. While there, I did encounter some trouble. Seems the light got stuck being in dim mode. Since I couldn't see the tailcap in the dark, didn't know how to "reset" it back to normal flashlight mode. After a while of jacking with it, got it back to normal.
Also used it just the other night while scene lighting to local PD on a meth lab bust and had no issues with the light then (scene lighting provided by lights from the rig, not the flashlight :p )
I think having to hold the light a certain way to bring up the different "effects" is a design flaw. Should've been incorporated into the switch, because if you're in the dark, you can't see what's printed on the back of the cap. Using it just as a regular flashlight, this thing DEFINITELY puts out the light! Overall, I'm still pleased with it. I really don't have a use for all the other fancy stuff, it's just that first night I used it I had nothing better to do while waiting and tinkered with it.
