I've looked all over for this unique setup & cannot find a no compromise solution.
Short of purchasing a Recon cab light setup with it's own odd flash patterns or purchasing an Atomic cab light setup that doesn't have a Scan/Sequential pattern, Im trying to find a Flasher that will accommodate an odd number of 5 outputs.. I have 5 cab lights, hence the reason I'm looking for 5 outputs
I would like to have just a basic in/out or side to side pattern for my 5 cab lights.
Naturally, the problem im running into is, every flasher has an even number of outputs. So it requires a bit of thinking or doubling up two outputs into a single cab light to get down too the 5 individual which then throws the patterns timing off.
Of course easiest route would be to just do a 3/2 alternating with the old Feinix Flasher I have kicking around..... But I'm rather stuck on this sequential side to side or in/out pattern as I've never seen it done on cab lights
The Sho-Me micro rotary can do 6 or 8 & has the patterns I'm looking for, but my concern is -
1. It looks rather slow like a really T/A is engineered
2. Because if how slow those T/A patterns are, there will be a funny/long pause while it triggers off that last unused #6 output & starts the pattern back the other way.
The old Feniex Flasher I have has somewhat of a in/out or scanner pattern, but one out of the five lights would have to be piggybacked to another & would cause one side too flash two at once as the outputs are triggering in a sequential fashion. Basically one side will get 2 lights on at once out of the 5 every time, so it's rather obvious
If anyone knows of a 5 output flasher or has anything productive too add please let me know.
Thank you for your help here.
I'll check back soon.
