Hi all,
So you are taking apart an old Aerodynic. Stuck bolts, penetrating oil, gentle taps, the works. Head snaps on you. Damn!
So you up the game and drill a bit into the bolt and in you go to insert Mr. Screw Extractor. Gentle you go, geeeentle, but hey! Now this guy breaks on you as well.
So you have a screw extractor stuck in a headless bolt, surrounded but so aluminum.
Tap/extractors are very hard metal, so good luck there.
I tried this kit of diamond burrs, bought at Lee Valley in Canada.
Keep it soaked in water for lubrification, but I was able quite easily to grind the tap away, exposing the bolt again. Then re-drill the bolt through (which I should have done in the first place), then re-tap and there you go.
The challenge is unless you have professional grade machinery, the drill bit won't keep on the broken tap/extractor, deviate in the aluminum, and destroy the alignment/hole.
Kit comes in a variety of shapes. I found the round tip better to get going, then cylindrical to finish off.
Hope this helps!
Antoine
Hope this helps!
Antoine
