Hey all.
I know how to change the gear setup thus changing the pattern on a 24eah AeroDynic, but I can't see how to change the inner-most rotators. They are half-covered by the bulkhead and the c-clamp on top of the other in-between gears isn't there. It's a circlip under the gear which isn't accessible...
The only way I've found is to take off the whole bottom plating and unscrew the holding nut of the rotator underneath then adjust it... Very time-consuming...
Anybody has a faster trick?
thanks!
Toon
thanks!
Toon
